射门几把机智,注册个账号这么麻烦
qq471847975 发表于 2019-8-8 03:51:10 | 显示全部楼层 |阅读模式 打印 上一主题 下一主题
5. System
·ETS runs as a 32-bit or straight 64-bit application depending on whether 32-bit components loaded (e.g. plug-in compatibility) prevent execution as a true 64-bit application (Details)
·As of ETS 5.5, ETS supports KNX Security to provide secure commissioning of the devices and secure communication during run time.
6. Commissioning
·Supports longer KNX telegrams (KNX long frames), which allows for faster commissioning (with devices which support this)
7. Licensing
·With the new ETS dongle, no re-installation of licenses on another computer is required for immediate plug & play functionality (Details)
8. Media Integration
·As of ETS5, there is better integration of the RF medium and this is reflected in two major points:
oIn the standardized management of RF configuration within ETS, including improved commissioning procedures and standardized setting of the RF parameters (RF device, RF line, RF coupler).
oChecking and safeguarding of restrictions in the topology when RF and other media are used at the same time.
